I have been reverse engineering the hardware of this 68332 based system in order to run my own software on it. What that software will be specifically, I don't exactly know yet.
This is a link to all of the pictures:
Beckman DU600 pictures
Note: many of these pictures are quite large, up to about 5MB
Here is copy and paste from the text file I use to document anything I reverse engineer from the hardware:
default setup of address space
this could change if software changes it
$00 0000 - CSBOOT, 1MB, onboard boot ROM
$10 0000 - CS0, 1MB, card 1 & 2, addon ROM card
$40 0000 - CS1, 1MB, card 3 & 4, onboard DRAM
$5C 0000 - CS8, 256KB, card 8, onboard SRAM
$60 0000 - CS2, 1MB, card 5 & 6, SRAM card
$B0 0000 - CS7, 1MB, 8 bit port, videochip
$D0 0000 - CS5, 16KB, I/O
$E0 0000 - CS9, 2KB, 8 bit port
$F0 0000 - CS10, 64KB, 8 bit port, I/O
$FF E000 - TPURAM, 2K
$FF F000 - internal CPU on-chip registers
CS5 controls U210, a 74AC138 for address decode
CS9 goes to a pin on J3, and nowhere else as far as I can tell.
CS10 goes to U25, a 74AC138 for address decode. also goes to pin on JA1 for daughterboard.
hardware I/O addresses:
CS5:0-7FF - UART1
This is the base address for the 68C681 on the mainboard. The base set of registers is repeated to fill the block of addresses.
CS5:802 - LEDS - doesn't clear IRQ
CS5:800 - PPORT - clears IRQ
This write address controls the parallel port output pins and the 4 onboard LEDs. Bit 15, 14, 13, and 12 control CR 50, 51, 52, and 53 respectively. Bit 11 controls the /SELECT_PRINTER line. Bit 10 controls the RESET line. Bit 9 controls the /LF line. Bit 8 controls the /STROBE line. The lower 8 bits control the data outputs. This address is repeated in the range 800-FFF everytime ADDR2 is 0. If any address in this range is read or written which has ADDR1=0 then the /ACK interrupt is also cleared.
TODO: figure out how to read the status lines for the parallel port, should be U57
CS5:1800-1FFF - J4
CS5:2000-27FF - RTC
Base address for Epson RTC registers
CS5:2000-2800 - EEPROM
CS5:3800-3FFF - DRAMC_CNTL
This address is used to write U719 (74AC573), an 8 bit latch. The actual chip seems to have the data lines hooked up backwards from the numbering in the datasheet, and it's attached to the high bits of the CPU data bus. The output of this latch is enabled or disabled by TPU channel 15. A 0 on the TPUCH15 pin on the 68332 enables output from this latch. Bit 6 and 7 appear to be unused. Bit 5 controls the DRAM controller /DISRFSH line. Bit 4 controls the DRAM controller /ML line. Bit 3 and 2 go to the PSU connector. Bit 1 and bit 0 seem to mask interrupt sources from the power supply board. A 1 masks the interrupts. The interrupts share a single interrupt latch flip flop and use IRQ1. They are cleared by a reset or reading this address.
CS7:0-FFFFF - ISA bus/SVGA controller
The SVGA controller is mapped here. 0-7FFFF seems to be mapped to I/O reads and writes (not confirmed) while 80000-FFFFF seem to be mapped to memory reads and writes. This is necessary because the video chip is made to work on an ISA bus which has separate memory and I/O spaces while the 68K does not.
chip is setup for MCLK on MCLK pin
ISA bus
Symmetric DRAM
single WE, multiple CAS
6 MCLK RAS cycle
44.74431MHz MCLK
32K ROM BIOS at C0000-C7FFF
8 bit BIOS ROM
Internal MCLK
3C3h is video system sleep register
CS7:02000-02007, 02406-02407 - ATA registers
This is piggybacked into the pseudo ISA bus used for the VGA controller. Decoding is done using a 74ACT138 decoding the top 6 address lines (A15-A10).
CS10:0-3FF - UART2
This is the base address for the 68C681 on the daughtercard. The base set of registers is repeated to fill the block of addresses. This also reappears at 2000-23FF
CS10:400-7FF - KB controller
odd addresses are status/command, even addresses are data. These registers may be repeated at 2400-27FF
CS10:800-BFF - MTR_CNTRL
This address writes to U18 (74AC573) on the daughtercard. It's bits control various motor functions on the daughtercard. Bit 7 seems to be disconnected by a jumper. If the bit 7 jumper were closed, bit 7 is ORed with J9 pin 3 and the resultant signal selectively inverts bit 4 of this same register. Bit 6 is connected to J8 pin 10. Bit 5 is the enable line for U6 and U7 (H-bridge motor controllers) which are driven by TPUCH6 and TPUCH7 respectively. Bit 4 controls the enable line of U15 and U16 (also H-bridge motor controllers). U15 and U16 seem to drive the same motor. The motor is stepped by TPUCH9 and the direction is controlled by TPUCH8. Bit 3, 2, 1 and 0 go to J3 pin 7, pin 19, pin 1, and pin 2 respectively.
CS10:C00-FFF - U20
bit 6 and 7 are not stored. Bit 5 is stored, but not used. Bit 4, 3, 2, 1, and 0 are connected through a 200 ohm resistor to J10 (batch) pin 6, 5, 4, 2, and 3 respectively. These IO addresses may be repeated at 2C00-2FFF
CS10:3800-3FFF
This selects a small PROM on the addon ROM board. Not all of the PROM is even mapped into the address space (many address lines are tied to VCC or VSS). see schematic.
IRQs:
IRQ7 - goes to J3 and U27 pin 13. appears to be used for expansion, possibly the optional floppy drive interface.
IRQ6 - JA1 pin 26, KBD controller output buffer full interrupt, pin 35, U26 pin 10
IRQ5 - UART1 interrupt request
IRQ4 - JA1 pin 5, UART2 interrupt request
IRQ3 - RTC periodic interrupt, U26 pin 13
IRQ2 - U26 pin 4, parallel port /ACK interrupt. Indicates printer is ready for more data.
IRQ1 - JA1 pin 6, causes U14 on daughterboard to latch, U26 pin 2, used for 3 interrupt sources on the PSU board, two maskable, the third not.
U29 is interrupt acknowledge decoder. For this to work, FC0, FC1, and ADDR19 must be enabled in place of CS3, 4, and 6.
IRQA7 - AVEC
IRQA6 - AVEC
IRQA5 - UART1 IACK
IRQA4 - JA1 pin 25, UART2 IACK
IRQA3 - AVEC
IRQA2 - AVEC
IRQA1 - AVEC
Periodic Interrupt Timer - IRQ5, vector $40 by original ROM
QSCI - normally disabled by original ROM, pins not connected
QSPI - IRQ6, vector $50 by original ROM
TPU - IRQ1, vectors $60-$6F by original ROM
TPU channels:
0 - used with ch 1 for stepper motor control. goes to U710 pin 2
1 - used with ch 0 for stepper motor control. goes to U710 pin 12
2 - used with ch 3 for stepper motor control. goes to U78 pin 2 and U76 pin 13
3 - used with ch 2 for stepper motor control. goes to U78 pin 10 and U76 pin 11
4 - used with ch 5 for stepper motor control. goes to U79 pin 2 and U76 pin 9
5 - used with ch 4 for stepper motor control. goes to U79 pin 10 and U76 pin 1
6 - used with ch 7 for stepper motor control. goes to JA1 pin 36
7 - used with ch 6 for stepper motor control. goes to JA1 pin 16
8 - used as direction control for stepper motor controlled by ch 9. goes to JA1 pin 35
9 - used to control the rate of movement of a stepper motor. goes to JA1 pin 15
10 - discrete I/O, seems to control beeper, 1 for on, 0 for off
11 - unknown. may be disconnected entirely.
12 - discrete I/O, goes to U67 pin 11
13 - unknown, may be disconnected entirely.
14 - U717 pin 3
15 - see section on DRAM.
ISA bus:
implemented for access to the SVGA chip. U44 GAL22V10 used for signal decoding.
pin 2 - CPU clock
pin 3 - NC
pin 4 - NC
pin 5 - /AS
pin 6 - R/W
pin 7 - U41 pin 3, OR of ADDR19 and CS7. must be IO select
pin 9 - OR of (NOT ADDR19) and CS7. Must be memory select
pin 10 - NC
pin 11 - NC
pin 12 - IOCHRDY
pin 13 - NC
pin 16 - NC
pin 17 - NC
pin 18 - NC
pin 19 - BALE
pin 20 - MEMW
pin 21 - MEMR
pin 23 - IOW
pin 24 - IOR-
pin 25 - NC
pin 26 - DSACK0 through U45
pin 27 - NC
to convert to 16 bit, DSACK0 must be cut. /IOCS16 must be OR'ed with /IO (pin 7 of GAL), /MCS16 must be OR'ed with /MEM (pin 9 of GAL), and the resulting two signals ANDed or NANDed. Of course, further logic simplification says that we could replace the two ORs and AND with all NORs and obtain an equivalent circuit using 3 NORs, thus potentially saving a chip. The resulting signal will then be latched on the falling edge of BALE. The Q output of the latch can then be NORed with SIZ0 to determine whether a 16 bit transfer occured. if the 16 bit transfer did occur, then DSACK output on the GAL is gated to generate DSACK1, otherwise it is gated to generate DSACK0.
of course, this means the upper data bus of the 68332 needs to be connected to the lower data bus of the ISA peripheral(s) (this swap fixes endianess issues), /SBHE needs to be connected to SIZ0, and the 16 bit select lines must have pullup resistors connected.
QSM:
TX and RX (SCI stuff) appear to be disconnected.
PQS6/PCS3 goes to U66, an OR gate which has the other pin going to an open jumper, JP70.
PQS5/PCS2 is used for U64 ADC channel 1/2 select
PQS4/PCS1 U67 pin 4
PQS3/PCS0/SS U66 pin 4
PQS2/SCK U68 pin 3 and sclk on U64 ADC
PQS1/MOSI U64 ADC SDATA output
PQS0/MISO appears to not be connected.
J4 pinout
pin closest to LEDs is pin 1. zigzag
1 - NC
2 - NC
3 - GND
4 - 5V
5 - RESET (active high)
6 - NC
7 - ADDR2
8 - RESET (active high)
9 - ADDR1
10 - NC
11 - ADDR0
12 - NC
13 - /WRS (write strobe)
14 - /WRS
15 - /RDS (read strobe)
16 - DATA14
17 - GND
18 - 5V
19 - DATA15
20 - NC
21 - DATA14
22 - CS5:1800-1FFF select (active low)
23 - DATA13
24 - ADDR18
25 - DATA12
26 - NC
27 - DATA11
28 - ADDR0
29 - DATA10
30 - ADDR0
31 - DATA9
32 - /WRS
33 - DATA8
34 - /WRS
35 - GND
36 - 5V
