Parts have arrived!
A project log for DNA-LAMP Diagnostic Device
Detect HIV, Ebola, Tuberculosis and other diseases, cheaply and reliably.
davidDavid 09/13/2015 at 18:532 Comments
With just a week to go, and two big boxes full of parts from Mouser on my bench, this week is assembly time.
On the last update, I showed off my new laser-made PCB boards, and now I have the parts to populate it. It's my first SMD design and I have to hand-solder everything as I don't have a reflow oven. So, just is case I mess up with such little time left, I have also ordered through-hole parts to make a perfboard functional prototype. The perfboard version will also be much easier to iterate on, as I use an Arduino Uno in place of a ATTINY841, which means I have enough programming space to include debugging and logging code over serial. I'm left with so little space on the 841 that I can't afford that luxury.
In parallel, I have Bst Polymerase for the wetlab experiments, to generate fluorescent sample to test my spectrofluorometer for the activated Calcien dye.
Wish me luck!
Adam Stankiewicz wrote 01/25/2017 at 12:24 point
Did you manage to finish it?
davedarko wrote 09/13/2015 at 18:59 point
Good luck :)
