More XNOR
A project log for Tern - Ternary Logic Circuits
A series of ternary logic gates and higher level components implemented in the real world.
mechanical-advantageMechanical Advantage 08/24/2015 at 05:580 Comments
Oops! The XNOR schematic is now updated to make it not fail miserably. Also, I remembered to put the truth table in this time. Here it is.
One thing I forgot to mention about the XNOR gate in a balanced ternary system is that the truth table is also the single-trit multiplication table.
-1 * -1 = 1
0 * 0 = 0
1 * 1 = 1
-1 * 1 = -1
This isn't super-useful since a bunch of XNOR's in a line aren't going to give you a multi-trit multiplier circuit, but it could be useful as a tritwise operator. Assembly programmers and embedded programmers do all sorts of wild sorcery with bitwise operators in binary where they only have between 6 and 15 (depending on the programming language). Just think what people will come up with when they could have *thousands* of tritwise operators available to them...
