Equality Gate
A project log for Tern - Ternary Logic Circuits
A series of ternary logic gates and higher level components implemented in the real world.
mechanical-advantageMechanical Advantage 09/08/2015 at 07:560 Comments
The equality gate outputs plus when both inputs are the same; otherwise it outputs minus. I initially thought to make this gate using a combination of two monadic 2's (+ - -), two 6's (- + -), and two K's (- - +). These could be arranged such that the gate always produces a - unless both inputs were the same. This would have required 8 comparators since 2's and K's are one comparator each and 6's use two comparators each. Instead, I worked out that, but judicious use of wired AND and wired OR I could build this gate using two P's (which can be implemented with just a couple of diodes), two A's (two comparators each), two 4's (one comparator each), and a single 2 gate (one more comparator). That comes to a total of only 7 comparators. Yay.
The P OR P gate is a Max gate
BBB
-0+
A--0+
A000+
A++++
The A OR A gate (The DAD gate by my naming convention) looks like this
BBB
-0+
A-000
A00-0
A+000
And the 4 OR 4 gate (DD4 gate) looks like this
BBB
-0+
A-000
A0000
A+00-
If you look at these three truth tables and just take the lowest value in each position (through the use of Wired AND) you get this truth table
BBB
-0+
A--00
A00-0
A+00-
By passing this through a 2 gate (+ - -) the -'s get turned into +'s and the 0's get turned into -'s and you get this
BBB
-0+
A-+--
A0-+-
A+--+
And thus we have a Equality gate. One that only returns a + when the two inputs are the same and returns a - otherwise. Here is the schematic.
