Reverse Engineering the Steering Column Switch
A project log for CAN BUS Gaming Simulator
Controlling a VW CAN BUS dashboard of a Polo 6R with an Arduino and a CAN BUS shield using the Telemetry API of Euro Truck Simulator 2
Leon BatailleLeon Bataille 10/22/2019 at 06:191 Comment
As mentioned before in my last project log, I used the long silence to dive deeper in the electronics of the Polo 6R.
In this project log I want to share some details regarding the Steering Column Switch (or in German “Lenkstockschalter”).
Its Task is to measure the rotation position of the steering wheel and it provides the switches for wipers, turning signal and light options.
A while ago I bought an old steering column switch from eBay as well as the case for it. I also bought a key switch for usage as a ignition lock.
Here’re some photos:
What I wanted to build was an USB interface which connects to the PC running the simulation game. That way you could control the corresponding functions with the simulation game.
I used an Arduino micro which can use USB HID profiles, so that it will be recognized as a keyboard by my PC.
Now my task was to find out the pin assignments for the column switch, which you can find below.
If you want to build this part of the project as well, here’s the Arduino sketch and the wiring diagram for it.
VW Polo 6R - Lenkstockschalter - Controller Software
by Leon Bataille
Version 1.0
Last modified: 04.07.2017
Pin assignments:
A0: HW  (FSW Wischwasser)
A1: 53c (HSW)
A2: (R) (MFA OK/Reset)
A3: I   (SW Intervallschaltung)
A4: 1   (SW Wischer-Stufe 1)
A5: 2   (SW Wischer-Stufe 2)
D2: SDA - I2C Arduino Communication
D3: SCL - I2C Arduino Communication
D4: L   (Blinker links <-)
D5: R   (Blinker rechts ->)
D6: 30  (Klemme 30: Lichthupe)
D7: 56  (Klemme 56: Fernlicht)
D8: 7   (GRA Reset/+)
D9: 8   (GRA Set/-)
D10: 3  (GRA an)
D12: auf (Trip/MFA+ auf)
D13: ab  (Trip/MFA+ ab)
More information on my hackaday project site:
https://hackaday.io/project/6288
#include <Wire.h>
#include <Keyboard.h>
//Pin Definitions
//-Inputs
int SW_WW = A0;
int HSW = A1;
int MFA_OK = A2;
int SW_INT = A3;
int SW_lv1 = A4;
int SW_lv2 = A5;
int tisch_hoch = 0;
int tisch_runter = 1;
int blnk_l = 4;
int blnk_r = 5;
int licht_hupe = 6;
int licht_fern = 7;
int GRA_plus = 8;
int GRA_minus = 9;
int GRA_an = 10;
int MFA_auf = 11;
int MFA_ab = 12;
bool state_GRA = 0;
bool lastState_SW_WW = 0;
bool lastState_HSW = 0;
bool lastState_MFA_OK = 0;
bool lastState_SW_INT = 0;
bool lastState_SW_lv1 = 0;
bool lastState_SW_lv2 = 0;
bool lastState_blnk_l = 0;
bool lastState_blnk_r = 0;
bool lastState_licht_hupe = 0;
bool lastState_licht_fern = 0;
bool lastState_GRA_plus = 0;
bool lastState_GRA_minus = 0;
bool lastState_GRA_an = 0;
bool lastState_MFA_auf = 0;
bool lastState_MFA_ab = 0;
void setup() {
  // put your setup code here, to run once:
  //PinModes
  //-> Alle Eingänge sind mit Pull-Up-Widerständen verbunden
  //Siehe: https://electrosome.com/switch-arduino-uno/
  pinMode(SW_WW, INPUT);
  pinMode(HSW, INPUT);
  pinMode(MFA_OK, INPUT);
  pinMode(SW_INT, INPUT);
  pinMode(SW_lv1, INPUT);
  pinMode(SW_lv2, INPUT);
  pinMode(blnk_l, INPUT);
  pinMode(blnk_r, INPUT);
  pinMode(licht_hupe, INPUT);
  pinMode(licht_fern, INPUT);
  pinMode(GRA_plus, INPUT);
  pinMode(GRA_minus, INPUT);
  pinMode(GRA_an, INPUT);
  pinMode(MFA_auf, INPUT);
  pinMode(MFA_ab, INPUT);
  pinMode(tisch_hoch, OUTPUT);
  pinMode(tisch_runter, OUTPUT);
  Keyboard.begin();
  Wire.begin();
void loop() {
  // put your main code here, to run repeatedly:
  //MFA_OK
  if (digitalRead(MFA_OK) == LOW && lastState_MFA_OK == 0) //If the switch is pressed
      lastState_MFA_OK = 1;
      Keyboard.print("i");
  else if (digitalRead(MFA_OK) == HIGH && lastState_MFA_OK == 1) //If the switch is released
  //SW_lv1
  if (digitalRead(SW_lv1) == LOW && lastState_SW_lv1 == 0) //If the switch is pressed
      lastState_SW_lv1 = 1;
      Keyboard.print("w");
  else if (digitalRead(SW_lv1) == HIGH && lastState_SW_lv1 == 1) //If the switch is released
  //blnk_l
  if (digitalRead(blnk_l) == LOW && lastState_blnk_l == 0) //If the switch is pressed
      lastState_blnk_l = 1;
      Keyboard.print("y");
  else if (digitalRead(blnk_l) == HIGH && lastState_blnk_l == 1) //If the switch is released
  //blnk_r
  if (digitalRead(blnk_r) == LOW && lastState_blnk_r == 0) //If the switch is pressed
      lastState_blnk_r = 1;
      Keyboard.print("x");
  else if (digitalRead(blnk_r) == HIGH && lastState_blnk_r == 1) //If the switch is released
  //licht_hupe
  if (digitalRead(blnk_r) == LOW) //If the switch is pressed
      Keyboard.print("j");
  //licht_fern
  if (digitalRead(licht_fern) == LOW && lastState_licht_fern == 0) //If the switch is pressed
      lastState_licht_fern = 1;
      Keyboard.print("k");
  else if (digitalRead(licht_fern) == HIGH && lastState_licht_fern == 1) //If the switch is released
  //GRA_an
  if (digitalRead(GRA_an) == LOW && lastState_GRA_an == 0) //If the switch is on
    lastState_GRA_an = 1;
    state_GRA = 1;
    Wire.beginTransmission(8);
    Wire.write("CCt_1");
    Wire.endTransmission();
    //GRA_plus
    if (digitalRead(GRA_plus) == LOW && lastState_GRA_plus == 0) //If the switch is pressed
      lastState_GRA_plus = 1;
      Keyboard.print("+");
    else if (digitalRead(GRA_plus) == HIGH && lastState_GRA_plus == 1) //If the switch is released
    //GRA_minus
    if (digitalRead(GRA_minus) == LOW && lastState_GRA_minus == 0) //If the switch is pressed
      lastState_GRA_minus = 1;
      Keyboard.print("#");
    else if (digitalRead(GRA_minus) == HIGH && lastState_GRA_minus == 1) //If the switch is released
  }//Ende GRA_an
  else if (digitalRead(GRA_an) == HIGH && lastState_GRA_an == 1) //If the switch is off
    state_GRA = 0;
    Wire.write("CCt_0");
  else //GRA_aus
    //GRA_plus
      Keyboard.print("c");
      //Transmit CC Status
      if (state_GRA == 0)
        state_GRA = 1;
      else
        state_GRA = 0;
  //MFA_auf
  if (digitalRead(MFA_auf) == LOW && lastState_MFA_auf == 0) //If the switch is pressed
      lastState_MFA_auf = 1;
      Keyboard.print("ü");
  else if (digitalRead(MFA_auf) == HIGH && lastState_MFA_auf == 1) //If the switch is released
  //MFA_ab
  if (digitalRead(MFA_ab) == LOW && lastState_MFA_ab == 0) //If the switch is pressed
      lastState_MFA_ab = 1;
      Keyboard.print("ä");
  else if (digitalRead(MFA_ab) == HIGH && lastState_MFA_ab == 1) //If the switch is released
That’s it for today. The next project log will be about the new instrument cluster setup.
Thanks for your support!
Riyad wrote 12/10/2019 at 11:56 point
Wow amazing work you did here, thank you. It will help me a lot for my school project.
I sent you a private message about another thing if you can check it :)
