Equipping the Board
A project log for CAN BUS Gaming Simulator
Controlling a VW CAN BUS dashboard of a Polo 6R with an Arduino and a CAN BUS shield using the Telemetry API of Euro Truck Simulator 2
leon-batailleLeon Bataille 11/16/2015 at 16:502 Comments
Today @Sepp and I equipped the PCB with the SMD components:
With this machine you're able to put the SMD components on the board.
The machine has a little camera on the positioning pin, so you're able to see what you're doing.
In the SMD oven the compents stick to the board with soldering cream, which becomes solder after 15 minutes of baking.
Thanks for the support! I'm courious when the project hits the 20.000 viewers mark.
Jeroen van der Velden wrote 11/17/2015 at 15:34 point
Almost 20k :), nice lab you got there, can they fix burned UNO`s lol :)
Leon Bataille wrote 11/17/2015 at 17:35 point
I got help from my colleagues. So I equipped the PCB in our lab.
