Updates to shoe plans based on properties of generators
A project log for HydroShoes
Hydro Shoes is a concept to generate the power for life, through the power of water, through the power of living...
jcellsworthjcellsworth 06/15/2015 at 23:200 Comments
Discussed some of the core concepts with fellow colleagues at the http://hacklab.to . Got some great feedback that continous periods of water flow would be valuable vs small surges. A minimum pressure, and higher flow based on higher pressure system was quickly added to the plans as I considered the feedback of how to make it work, vs just accepting there was reason why it may not work :-)
