The ROBOScythe almost ready for use.
The new design based on VSLOT 20x20 extruded aluminium
The drive system based on two MG996 servos and GT2 pulleys. Side effect: I created a GT2 Pulley pack on Thingiverse.
The cutting equipment based on a BLDC motor. ( +ESC )
The blade has three wings with Robotic lawnmower razors (from OBI). You can use damilhead optionally
The ROBOScythe blade has a shield. And this shield built it with two pressure sensors.
The third "gear" is a tail and stabilizes the device.
And that's all together.
Hi there, using cryptocurrency for financial transactions on the Indian <a href>https://bc-game.app/payment-methods/</a> has been a turning point for me. The platform supports a wide range of cryptocurrencies, which makes it incredibly versatile and convenient. The deposit and withdrawal process is smooth and hassle-free, and transactions are processed quickly. I especially appreciate the increased security that the use of cryptocurrency provides, as it ensures that my financial data remains confidential and protected.I would definitely recommend you to check out their review.
