Serial Stream to 70cm to WiFi to Telnet
A project log for High Power Experimental Rocket Platform
Experimental high power rocket with active stabilization, live telemetry, autonomous GPS guided recovery and HD video
j-m-hopkinsJ. M. Hopkins 02/27/2016 at 02:040 Comments
So there is still a little bit left to do here, but let me explain my datapath from before this board was created. The board has a 7805, filtering caps, reset button, APC220, and ESP8266. And a few extra RF goodies laying around it.
The old datapath was as follows:
  1. Telemetry serial stream generated from altimeter's onboard microcontroller
  2. Transmitted from the avionics bay through a APC220 70cm transiever
  3. Received by the 6 element yagi, into my ground station's APC220
  4. Serial stream piped to the laptop from a translation microcontroller
The new ground station board follows the same path, but extends it to:
    4. Serial stream into the ESP8266 WiFi microcontroller
    5. Cell phone acesses the data stream via a WiFi telnet session
    This allows me to not have to haul around the laptop unless I want to, plus I can now control everything from my cellphone. How cool is that?
    The next step is to put it all into a real box.
