Vinduino Project Savings
A project log for Vinduino, a wine grower's water saving project
Monitoring soil moisture at different depths to determine when to irrigate, and - more importantly - how much water is needed. Save 25%!
reinier-van-der-leeReinier van der Lee 10/24/2015 at 23:120 Comments
Summary
The Vinduino project saved 25% , or 430,000 gallons, irrigation water.
Cost saving on water and labor was $1,925.
Project component cost was $635.
Irrigation Cost Before Vinduino
In 2014, and the years before that, we had irrigation managed by our vineyard management company. They decided when and how long to irrigate. This was done manually. Someone drove up to the vineyard, opened the valves, and returned later that day to close them again. Apart from the labor cost, my concern was that I had no control, and no way to tightly manage water in another year of severe drought.
CostIrrigation QTY
Irrigation water (2014)$ 3,2002,325 HCF
Irrigation management (2014)$ 1,125
Total cost for irrigation$ 4,325
Savings
CostIrrigation QTY
Irrigation water (potential)$ 2,4001,750 HCF**
Irrigation management (2015)$ 0
Total estimated annual savings
for irrigation
$ 1,925575 HCF (25%)
(430,000 gallons)
** this is the goal for 2015, actual is a bit higher due to equipment failure and overestimated water requirement directly after installation. Subtracting these, we would have met the target saving of 25%, and have repeatable results next seasons.
Cost summary
Installed sensors cost (1 x Watermark, 10 x gypsum)$50
2 x DC latching valves + timers$450
Vinduino handheld reader + Vinduino remote node$135
Total project components cost$635
Including one time cost for new irrigation valves and irrigation timers, the payback period for this project is less than one year.
The financial savings are an additional bonus for saving water!
Developing Countries Configuration
A minimum cost Vinduino setup for developing includes: a handheld reader, multiple gypsum sensors, and a salinity probe.
The total estimated component cost for this is $60. High volume purchasing can bring cost down significantly.
While not as convenient as a remote reading station, taking daily measurements in the field is considered sufficient for keeping track of soil moisture and estimating irrigation time.
The salinity probe allows salinity measurement of soil, and checking of irrigation- and drinking water quality.
Soil sample measurements should be taken a few times per year, avoiding crop loss due to soil salinity.
Vinduino Component Cost
The handheld reader has evolved into a multi-purpose agricultural meter. It can be used to measure :
Low volume component cost estimate is $51.50
(excl. VAT and component shipping cost)
The remote reader station (picture below) can measure :
Connectivity options include log range RF modules or WiFi (ESP8266)
The board can be configured to control DC latching irrigation valves and measure water pressure (as feedback that valves work properly). This will require an additional motor driver board and DC/DC boost converters.
Low volume component cost estimate is $87.50
Plumbing Cost
I installed 2 x DC latching 2" irrigation valves ($125 each) and control them with battery operated timers ($100 each). The timers are set for daily irrigation, and the irrigation time is adjusted weekly. For next season, the goal is to replace the timers with Arduino-based irrigation control.
