4-Pole 3.5mm socket for sensors that speak I2C
A project log for A Versatile Labtool
A cost effective, multi-pronged data acquisition tool to turn your computer into a workbench for science and electronics experiments.
jithinJithin 07/26/2015 at 21:190 Comments
Having to Plug in numerous wires in a particular order each time is an unnecessary hassle as well as a risk. In case of sensors that speak I2C , four connections (Vcc,GND,SCL,SDA) need to be made. The Clock and Data lines can e shared over multiple devices.
Using a 4-pole socket has numerous advantages
At this point, I2C lines are available on the 20-pin expansion slot, a 4-pin berg pin on the center of the top panel, and over the 4-pole 3.5mm socket
