Knocked over....
A project log for Magnifier Lamp
A home made LED magnifier lamp
Andy from WorkshopshedAndy from Workshopshed 07/23/2015 at 18:180 Comments
The base is going to need a bit of a redesign, if you extend the lamp all the way out then it topples over. I plan to chop a hole in the side and fill with some lead. I can also use this to put a panel on for the power socket and switch.
