µ7 (formaly an own project)
A project log for tiny7
small seven segment display for plugging on an ISP programming header of an Atmel Board or an Arduino
alexAlex 09/23/2016 at 18:100 Comments
To tidy up a little bit my projects I will push the µ7-project into a log of tiny7 The following text is mostly just a copy from the old µ7 project page:
This is just an idea how to make #tiny7 smaller. Smaller IC package (QFN) and samller parts are used. The dispaly is 0,36'' 7 segment display.
It should be 100% compatibel with #tiny7 . The same library should be used. But µ7 is not chainable (yet?).
https://cdn.hackaday.io/images/5830351449523648148.JPG
