New Responsive Design WebGUI
A project log for Tick Tock Timer
The Tick Tock Timer is a School Bell timer packed with features
Jasper parkerJasper parker 09/16/2017 at 03:511 Comment
The most requested features from customers has been a way to use the timer with a smart phone and PC.
After considering development times for iPhone/Android/Windows apps I decided a small light weight responsive webgui would be the best cross platform solution.
In developing the WebGui I came accross the following challenges
 - Running out of RAM on the ESP8266
 - Bugs in the Web Server Library
I ended up having to modify the WebServer library to get Chunked Encoding to work properly as serving up the webgui using a traditional HTML transfer with a Content-length entry in the header was not possible, causing End Of Heap RAM reboots not matter what I did.
I really felt I was running the little ESP past its limits however after many many hours of work I have a stable responsive webGui being served up from the Tick Tock Timer.
--This functionality is now available though OTA firmware update--
The WebGUI supports the following
Interface designed using Boot Strap and Pingendo.
andrewpk2020 wrote 10/18/2020 at 06:14 point
Thanks for sharing insightful information and projects about Telecom industry. I have been working in telecom industry for last couple of years and worked for various projects. I just have filled contract termination template on
https://www.kuendigung.services/vorlage/kuendigung/telekom. They are an online contract termination service provider. They have a quick way to terminate with easy to use templates.
