It all began with a big letdown.
Back in 2010 when the grass was greener and the blues bluer i decided to stop ruining my eyes and start taking a part in the e-ink revolution. I choose the IREX DR1000S for obvious reasons. The size and the possibility to scribble. But it failed horribly on me.
And here is how it did...
After some years have gone by and some occasional remembrances on the joy of reading the big e-ink screen tickling me it only happened by chance that i finally took on the work.
The main problem i had was the power issues. From the beginning until now. The original Varta LiPo was really dead by now so i knew i needed to get some replacement battery. Many have done that surgical operation before me, so i was not afraid. It was known land.
Just another day at the local supermarket i found a slim, big and black thingy sticking out a "battery recycling/collecting" bin. It was a Macbook Air's battery compartment. I tear it open (very good sticking tape and glue there is) and savaged 3 working 3.7V LiPo cells each with double the capacity of the DR1000Ss original cell. The connection leads for the 4th cell where torn out during the removal procedure.
Ten minutes later i cracked the DR1000S open following this guide, snipped of the original batteries connector, soldered it too one of the frankenmac's batterirs, connected it and et voilà the green LEDs started to glow and a screen displayed the familiar IREX boot up screen. Now everything was good. I fully charged and it was almost like a dream come true.
On the left the DR1000S original Varta cell - PLF503759 3.7V 1300mAh. Next to it is the Macbook Air's cell - the Sanyo UPF3768111 3.7V 3800mAh battery.
[INSERT irex bootup video]
With the extra mWh i could use the device almost the whole day. I was happy!
But it did not last. I charged the device maybe 10 to 15 Times. Everything was alright, except maybe the battery gauge that was a little confused by the extra capacity.
Then one day i drained the battery fully and let the device sit alone for a week.
After that it was bricked as i would call it. Some other people have got the same symptoms and no one seems to have had much success in fixing this issue.
The device does not fully boot. It stops progressing a few seconds after the boot starts and displays some color coded blinken lights. All this while the boot animation endlessly continues (a dot running in circles) until the battery is drained.
[INSERT BLINKEN VIDEO]
Not much use for anything.
The debugging options on this device are really limited.
No Documented JTAG
No Documented UART
And a mysterious, undocumented connector on the bottom.
Some people have tried getting USB OTG to work on the DR1000, but they didn't succeed. [INSERT links to mobileread threads, Description blinken pulses]
No one so far seems tho have searched for or found any usable debugging interface
BUT THERE IS HOPE!
There is a very nice Labeled PCB.
It looks like there are some boundry scan test points right next to one of the CPLDs.
A bunch of freely available source code
[INSERT PLATFORM SPECIFIC CODE SNIPPLETS GPIO,UART ASSSIGNMENT]
There is a bunch of useful software for helping in finding some debug interface. For instance JTAGenum and RS232enum by cyphunk.
The CPU of the DR1000S is a very well documented an broadly used Freescale i.MX31.
Understanding the Device
The following tables will be updated regularly. When finished it should map labels->locations->functions and working/non working state.
the pcb
label manufacturer part function
U1 NXP ALVC164245 L8A7S3 19 UnGO823D 16-bit dual supply translating transceiver
U2 NXP ALVC164245 L8A7S3 19 UnGO823D 16-bit dual supply translating transceiver
U3 NXP ALVC164245 L8A7S3 19 UnGO823D 16-bit dual supply translating transceiver
U4 NXP ALVC164245 L8A7S3 19 UnGO823D 16-bit dual supply translating transceiver
U5 NXP ALVC164245 L8A7S3 19 UnGO823D 16-bit dual supply translating transceiver
U6 NXP ALVC164245 L8A7S3 19 UnGO823D 16-bit dual supply translating transceiver
U7
U8
U9 NXP ALVC164245 L8A7S3 19 UnGO823D 16-bit dual supply translating transceiver
U10
U11
U12
U13
U14
U15
U16
L8HM N192 816
U17
U18
U19
PEKI
U20
PEKI
U21 Maxim MAX3377 EEUD 4815
U22
U23 Hynix HY27UF082G2A TPCB 809A
U24 NXP ALVC164245 L8A7S3 19 UnGO823D 16-bit dual supply translating transceiver
U25
U26
U27
U28 Texas Instruments YE08 85K Q4 EK6-D
U29
U30
U31
U32
U33
U34 Maxim MAX3377 EEUD 4815 Low-Voltage Level Translators
U35
U36
PEKI
U37 NXP 505C 0203 ZPD822F
U38 NXP 505C 0203 ZPD822F
U39
U40
U41
U42
U43 MYSTERYPART
U44
U45
U46
AC2A
U47
U48
X07C
U49
U50
U51 Hylinx HYB18M512 160BF75 WVV15804 0816 B
U52 NXP ALVC164245 L8A7S3 19 UnGO823D 16-bit dual supply translating transceiver
U53 NXP ALVC164245 L8A7S3 19 UnGO823D 16-bit dual supply translating transceiver
U54
U55
7W53 8 C
U56
7W53 8 C
U57
X61C
U58 Hylinx HYB18M512 160BF75 WVV15804 0816 B
U59
U60
U61
U62 Freescale MC34704 4APA8 Multiple Channel DC-DC Power Management IC
U63
labels on the pcb
pin label function value part of located near tested
BAT_MAN_GPIO2
COMPARE
WD_RST
CLK0
DVTS0
DVTS1
SJC_MOD
FUSE_VDD
I2C_PMU_CLK
I2C_PMU_SDA
VPG0
VPG1
RESET_HOST
RST_OUT_3
CAPTURE
PWR_FAIL
RESET_DEV
IMX_BU
VBORDER0
VBORDER1
DELTA_RST
MCU_RST
+1V8
1V8_VBAT
1V8_CTRL
DEBUG
PWR_SW1
PWR_SW2
PWR_SW3
TDO_DIS
TMS_DIS
TDI_DIS
TCK_DIS
BUZZER2
BUZZER3
VBATT
VNEG
VP0
5V_VCOM
+5V_VCOM
+5V
GND
USBDEV_VCC
1V5_CTRL
+1V5
VEE
VGG
+3V3
connectors on (or missing on) the pcb
label
connector type number of connections
CN1
CN2
CN3
CN4
CN5
CN6
CN7
CN8
CN9
CN10 UNKNOWN 14
CN11
CN12
CN13
SD CARD 10+1
CN14
CN15
CN16
CN17 UNPOPULATED 3
CN18 UNKNOWN 30
CN19
CN20
CN21
CN22
CN23
CN24 UNPOPULATED 3
CN25
CN26 Mini USB
5
CN27
CN28
CN29
CN30 UNPOPULATED 3
CN31
CN32
CN33
CN34
CN35
CN36
the X labled parts on the pcb
label manufacturer type function pins
X1 UNKNOWN
6
X2
X3 UNPOPULATED
4
X4
D268F
X5
D268F
X6
DA810C oscillator 2
X7
X8
X9
X10
testpoints
TP1
TP2
TP3
TP4
TP5
TP6
TP7
TP8
TP9
TP10
TP11
TP12
TP13
TP14
TP15
TP16
TP17
TP18
TP19
TP20
TP21
TP22
TP23
TP24
TP25
TP26
TP27
TP28
TP29
TP30
TP31
TP32
TP33
TP34
TP35
TP36
TP37
TP38
TP39
TP40
TP41
TP42
TP43
TP44
TP45
TP46
TP47
TP48
TP49
TP50
TP51
TP52
TP53
TP54
TP55
TP56
TP57
TP58
TP59
TP60
TP61
TP62
TP63
TP64
TP65
TP66
TP67
TP68
TP69
TP70
TP71
TP72
TP73
TP74
TP75
TP76
TP77
TP78
TP79
TP80
TP81
TP82
TP83
TP84
TP85
TP86
TP87
TP88
TP89
TP90
TP91
TP92
TP93
TP94
