Assemblage
A project log for Home Power Usage Monitor
Gather power data from the breaker panel and beam it to a Raspberry Pi for storage and web serving
drew-yenzerDrew Yenzer 08/26/2015 at 00:390 Comments
Well I was able to get the board soldered up, and plastic case modified to mount everything. It looks pretty good so far, I think. Here's some pictures:
You probably noticed the ribbon cable dangling off the LCD. Just when I went to clamp on the IDC connector, I found out the cable was much too big for it. Turns out for a 0.05" pitch connector you need half of that, or 0.025" pitch cable. No where does it explicitly tell you this, but if you look at the connector drawing, then find out how wide the ribbon cable is, you'll see it. So I've got some smaller cable on order now.
Once I get that settled I can actually start testing out some code!
