Live video of ROM module making
A project log for PDPii
PDP-11 compatible motherboard in mini-ITX form factor
SHAOSSHAOS 05/06/2018 at 03:5611 Comments
I live streamed creation of ROM module board in Eagle v5 running in MacOS X 10.4 on the one of the latest PowerPC G4 laptops that I own since 2007 ;)
Later I edited archived videos to remove pauses and made it 8x faster:
Results (ROM 64K board) added to GitHub and here in Files:
danjovic wrote 05/14/2018 at 09:27 point
Very cool video. Making PCB layouts is kinda relaxing.
SHAOS wrote 05/15/2018 at 03:18 point
Thanks, next video will be even cooler because it's true 1280x720 :)
YT is currently processing it...
SHAOS wrote 05/12/2018 at 01:09 point
Wow, somebody removed skull after I published this video :(
Ted Yapo wrote 05/12/2018 at 13:31 point
I lost a few skulls in the past day or so, too. Maybe a bug like the
"lost follows" that was happening a while back?
SHAOS wrote 05/12/2018 at 14:34 point
yes, may be it's some kind of glitch
Ted Yapo wrote 05/11/2018 at 13:38 point
Thanks for posting the video!  I wish there were more routing videos around.  It's a relaxing way to see how someone else approaches the problem and maybe pick up a few ideas.
SHAOS wrote 05/11/2018 at 14:02 point
Thanks. I'm pretty sure I made some mistakes obvious for professionals ( I'm not hardware professional - I'm a software guy - so I may not know something, but for hobby level it should be good enough ; )
SHAOS wrote 05/11/2018 at 14:03 point
Also I'll try better video quality in my future live streams - my current setup is a little bit overcomplicated :)
K.C. Lee wrote 05/12/2018 at 07:48 point
 For me, it is an iterative process doing hand routing and it take a very long time to get to a point that I am fully satisfied - also looking for stuff like high frequency digital signal return path that most seem to ignore.  My routing video done in real time would be really boring because it take days or even months to do it.
Probably more interesting thing to do is a hand routing contest/challenge with modern SMT packages.  :)
Ted Yapo wrote 05/15/2018 at 03:21 point
high frequency return path is easy: it's the unbroken ground plane that you have under each and every signal trace :-)
SHAOS wrote 05/11/2018 at 06:22 point
Edited video of this live stream just published - see above
