We have RGB..!
A project log for Soft Propeller
DIPFORTy1 "Soft-Propeller" Zynq-7, Dual CortexA9+ FPGA DIP40 Parallax Propeller I compatibles footprint
antti-lukatsAntti Lukats 07/16/2015 at 17:030 Comments
RGB or maybe GBR, we had to replace the RGB as the one we got had different pinout to what was initially designed in.
But after small rework, very first test design with vivado, with pure block design and no use of ARM cores, just worked.
The LEDs are with full brightness, no PWM.
Very stupid design but it does at least check all LEDs are working. Does now work out of flash too, the FPGA is loaded by ARM cores from SPI flash that is mounted as normal linear Flash. The ARM Cores can execute also directly from SPI Flash...
