First Pad Completed
A project log for Drum Master
Electric drum set based on Teensy 3.1 and Audio Board
the-big-oneThe Big One 08/17/2015 at 02:320 Comments
The first two pads are now completed, and all the pads' wood is finished with Danish Oil and are thus ready for assembly. Assembling each pad takes about 10 - 15 minutes from here, so we're getting close.
Some pictures, before and after the coat of Danish Oil:
... and, the first assembled + tested pad on the frame:
(This is one of the cymbals, and thus has a mute switch in addition to the pizeo. I had debated with myself over the different options for muting cymbals, and after much thought decided to go with a simple panel mount push button instead of some of the other methods such as touch sensor or some sort of pressure switch.
