Adding Z C beam to X gantry
A project log for OpenBuilds C-Beamâ„¢ Machine Build
C-Beam Machine is a CNC machine design based on the popular V-Slot linear guide system.
charliexcharliex 07/26/2015 at 19:300 Comments
Put together the X + Z gantry.
Plate onto the 250 mm C Beam
Add the 10 mm M5's, some of them go into the large holes
I added tape over the heads to hold the bolts in place.
Now add the washers.
loosely add the t-nuts, just enough to hold them in place and align them like this
Insert into 250 mm C Beam
I squared mine off with a mini machinist square
And tighten down the M5 bolts, i did a couple snug then tap gently with a soft non marring hammer, and checked it for squareness as a i tightened it down.
Add it to the 500 mm C Beam
Adjust the eccentrics so they are nice and tight, so you have trouble turning the wheel by hand, check squareness and movement so there is no slop, make sure all the wheel nuts are tight
