Plans For DIY Mechanical Feeder [Small Aquaponics]
A project log for Hacking the way to growing food
Using Technology And A Hackers Mindset To Grow Food. Last Updated [16/01/2021]
michael-ratcliffeMichael Ratcliffe 08/16/2015 at 15:500 Comments
I have had a lot of requests for a how to on making the mechanical portion of the feeder. Well Here it is:
Spec's
20mm:
-federate [need to measure this]
-can handle food upto 4mm
25mm
-1L/min Federate with 50:1 ratio box
- can handle pelted food upto 6mm
What you will need:
Tools:
-Hand Drill
-Allen KEys
-Philips Screw Driver
25mm Feeder Parts
>25MM X 235MM SDS auger wood drill bit
>25mm Pvc Inspection Tee
>28mm metal saddels [28 mm MSBZP] two of these
> Aluminum Flexible Shaft Coupling 6mm to 10mm [SDS is 10mm, motor 6mm]
> MFA 919D 12v dc motor, 50:1 and lower gear ratio
>8 wood screws
>2’ Length of 3x2” wood
> 5cm length of 25mm PVC piping [for fitting the hopper]
As You can see the Motor is an expensive one, I had one of these knocking about but any similar power slow rotating [120 rpm and below] 12v motor should work. It is important to get one that has a shaft height [ie the heigh of the shaft above the mounting plate] of blow 14mm. If it is lower you can always mount the motor on a shim.
20mm Feeder Parts:
>20MM X 205MM SDS auger bit
>20mm Pvc Inspection Tee
>25mm Pvc Saddels [two of these]
> Aluminum Flexible Shaft Coupling 4mm to 10mm [SDS is 10mm, motor 4mm]
>Electric 2 Pin Connector DC12V 40-50mA 10RPM DC Geared Motor
>8 wood screws
Feel Free to use this design, modify it and make it better if you can see a way to do so.
Want to bring your fish feeding into the rest of the automated system, the next blog will be on controlling these feeders to optimise fish growth.
