2mm aluminium sheet for emi shielding. Not connected to either digi ground plane or analogue.. Should it be?
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
ben-bilesben biles 01/20/2020 at 14:410 Comments
Aluminium emi between digi and analogue board
