Heated Bed current draw
A project log for Printrbot Simple Metal - Bed upgrade
I need a larger print area in order to print a printer
reniermRenierM 08/22/2015 at 12:060 Comments
So far I've measured just over 11A when both the Heated bed and the Hotend are both active.
MAKE SURE YOU ARE AT EXACTLY 12V, i had my Power Supply set at 12.1V and continuously had random disconnects when heating or cooling the heated bed, must have been over voltage protection doing its job :)
I've also added {M140 S0 ;} to the end G code section under "Printer Settings" in Slic3r.
this disables the heated bed after the print finishes.
**UPDATE: I think I've found the answer, http://help.printrbot.com/Answers/View/5242/Brown+out+reset:+Printrboard+or+PSU
Bill had a similar problem "Bad heated bed. The bed was sporadically pulling enough current to trip the PSU short-circuit protection. I replaced it with a RepRap MK2B heatbed dual power from Amazon and after 20+ hours of trouble-free printing it is clear that that was the problem."
It may be that the fancy Kapton Nichrome heater is causing a similar problem on my board.
At the moment the reset problem seems to be contained to the heat up process and just after a print. luckily whenever I get the print stared it runs through and only resets and hangs up after finishing so I'm OK with it for now until I find a solution, It also works much better since I added the indicator LED.
