Lazy Susan planetary gears
A project log for The tiny radio telescope
Ever wanted a meteor detector? Interested in radio telescopes? This project is for you
Paul ScottPaul Scott 08/14/2015 at 06:550 Comments
Designed and ready to print. I am not yet sure that the gear ratio will be high enough for a NEMA 17 stepper motor to drive it, but I suspect it should be OK. The antenna is not very heavy, but I am a little worried about possible wind damage....
