Hotglue Everything!
A project log for Logicoma-kun
A working model of a Logikoma from "Ghost in the Shell: Arise".
dehipudeʃhipu 08/24/2015 at 17:170 Comments
The acrylic nuts and bolts finally arrived, so I can put it all together. Since I wasn't really sure how everything will be attached when I designed the laser-cut parts, I simply hotglue them together where there is no room for bolts.
Next step is connecting all the wires properly and programming. I also want to try and fit a distance sensor in the eye, and add the hands and snout.
