Reading up on IEC Fusion Theory
A project log for Inertial Electrostatic Confinement Fusor
A low-cost, experimental setup for D-D fusion
nathanstrachenNathanStrachen 08/16/2015 at 23:070 Comments
Here are just a few of the sources that I will begin to dig through:
http://ssl.mit.edu/publications/theses/PhD-2007-McGuireThomas.pdf
http://www.fusor.net/
http://ssl.mit.edu/publications/theses/PhD-2007-DietrichCarl.pdf
https://smartech.gatech.edu/bitstream/handle/1853/21828/seltzman_andrew_h_200805_phys.pdf
http://www.dallastown.net/cms/lib6/pa01000011/centricity/domain/99/kovalchick.pdf
http://robofusor.aditl.com/
