Testing the 3D printed front nose. Looks quite good. Minor adjustments needs to be done.
Printed with PrimaSelect PETG @240C, 85C bed, 3shells and 15% infill (Very solid outcome).
-Countersink need to be adjusted to cut the body.
-The Integrated ZR300 camera need some cover on the back.
-Check if one can use a 90 degree USB instead of a normal USB head.
