Helmholtz Coil
A project log for Aurora Observatory
BLE Triaxial Earth Field Magnetometer to alert for Aurora Borealis activity and for earth field work
chasinspinChasinSpin 08/24/2015 at 16:110 Comments
Needed a Helmholtz Coil to test the sensitivity and calibrate the coils. I've designed a 3D printed Helmholtz Coil for this purpose. The best is, it's easy to build, cheap and it does all the math for you and spits out the configuration / sensitivity of the coil using OpenScad:
Helmholtz Coil
