Switched from Relay to Darlington NPN Power Transistor
A project log for WeMo Garage Door Opener
Connect a Belkin WeMo device to your garage door to allow open/close remotely, tracking door status, and integration with IFTTT
cdhcdh 04/07/2014 at 22:530 Comments
Initially used a relay to trigger the garage door which just wants to be shorted to ground for a half second or so. But for the final version went to a (solid state) Darlington NPN transistor which is much simpler, cheaper, smaller, and just the right way to do it.
