New battery holders and cells!
A project log for LiFePO4wered/USB
LiFePO4 battery technology, made easy for makers
patrick-van-oosterwijckPatrick Van Oosterwijck 11/02/2016 at 19:230 Comments
A complaint I sometimes heard about the LiFePO4wered/USB (the only complaint really) was that the battery didn't fit well in the battery holder. This was definitely justified: being a perfectionist myself, it was something that bothered me as well.
There's a solution now: all new units will be shipped with a new battery holder and cell that provide a much better fit:
The new cell is smaller (shorter) because it has a flat top instead of a button top. The old battery holder had a reverse polarity protection feature in the plastic, and although the new cells seem to work in it, the feature is really designed for a button top cell. So I decided it was safer to switch to the new battery holder I've been using for the #LiFePO4wered/Pi and also use it for the LiFePO4wered/USB now.
The only relevant difference (aside of a much better looking unit :)) is that the battery holder pins are shorter than they used to be. I already altered the product brief to allow for the variation in physical dimensions a while back.
