Ivan's Design Animations
A project log for Ivan the Teambuilt Robot
An e-NABLE robotics project to give hands to those without use of their hands. Designed with your help.
Les HallLes Hall 03/07/2017 at 22:104 Comments
Have a look at these fun animations showing Ivan's parts in action. This is the first (nearly) complete design, ready for construction - it just needs some screw holes and some attention to detail on the toolhead. The base is completely ready for construction, can't wait to build it!
below is Ivan in operation, the complete robot printed in carbon fiber PETG filament.
I have two detailed animations of the gears working. The first is the planetary gear box in the base:
The second is a close-up of the hinge gears that work the arm:
Below is an animation of the Grab-Tor hacked claw:
It is made of e-NABLE's Raptor Reloaded finger parts, designed by STEM school kids - very imaginative! I arranged the three fingers into a "three jaw chuck", representing the index finger, middle finger, and thumb working together in a human hand.
Les
Les Hall wrote 03/08/2017 at 08:33 point
TY dave.  I just printed the first gear tonight, the sun gear of the rotary base.  It looks like the hole for the axle is too small but other than that should be fine.
davedarko wrote 03/08/2017 at 08:38 point
that's what knifes and first prints are for :)
Les Hall wrote 03/08/2017 at 08:44 point
Yes and Dremel tools!  :)
davedarko wrote 03/07/2017 at 23:39 point
groovy :) looking forward to see it getting started!
