Compressor
Heater(Iron tank)
Pipe
Water tank(Transparent tank)
Activity
Fill the compressor tank with the fuel of Biogas from the biogas plant. Then fill the Heater(Iron tank) tightly with plastic (Bottle,carry bags etc.).A Burner connect under the iron tank.
The tank tightly heated with the gas from the compressor .The plastic waste in the iron tank will be melt and changed to liquid,which flows through the pipe connect on the top of the iron tank. The pipe from the top of the tank in inserted in the top of the tank .The tank should be keep away from the air. The liquid flows through the pipe will be floated on the top of the water in yellowish colour(Diesel)
