final assembly
A project log for cheap lab bench shelf add-on
Got a free standing lab bench, but missing a shelf for test equipment?
rawerawe 09/04/2015 at 22:070 Comments
One hole in the corner, 4.25mm from both edges, used to temp. mount the shelf and mark the locations of the other holes:
The holes are symmetrical to the bench leg, but the screw heads are too big:
Countersink...
et voilà:
some bench cleanup /re-arrangement later:
