XPT2046 touch on ESP8266
A project log for DIY Chumby-lite
ESP8266-based WiFi LED light controller and clock
Spiros PapadimitriouSpiros Papadimitriou 09/16/2015 at 16:351 Comment
We have touch input! First successful test:
The chip is a TI ADS7843 clone (even table references in it's datasheet match TI's datasheet, and not it's own numbering -- had me scratching my head, until I found the TI datasheet, and then it made sense :).
Had to write driver from scratch, to use hardware SPI (otherwise there aren't enough pins). MOSI/MISO/CLK are shared with the ILI9341 display driver. While at it, added support for differential mode (code I could find used bitbanged SPI and single-ended mode). The code is currently a frakking mess, but once cleaned up, it'll be on github.
So, the $22 Digole can be replaced by a $7 generic module (running ucglib, a much nicer graphics lib, too!). Getting closer to the ~$13 mark, which makes much more sense for this device.
Edit - initial code here: https://github.com/spapadim/XPT2046
Andy Coulson wrote 09/13/2018 at 12:55 point
What is the pin hookup ?
