Hexabitz Module Factsheet a.k.a. Documentation
A project log for HEXABITZ - Modular Electronics for REAL
A new kind of electronic prototyping!
hexabitzHexabitz 04/03/2018 at 02:580 Comments
Factsheets are Hexabitz's take on documentation! They're a mix between a hardware datasheet and a software cheatsheet. They should get you up to speed on any module and provide quick access to the most needed information, e.g., major component part numbers, module APIs and Commands, etc. The software section features some simple examples as well to provide quick help with the syntax. Factsheets are designed to be printed double-sided and kept in nylon sheet covers so that they're easily accessible when you need them.
Each module factsheet should generally contain the following information:
Factsheets are available in the project files section.
Module Categories
Hexabitz modules are usually organized in the following categories. The factsheets are color-coded according to these categories to help you classify them quickly:
