Stack Address Counter: Some Numbers
A project log for ED-64: A discrete 8-bit computer
ED-64 will be an 8-bit computer built with discrete components, and will feature a ferrite core memory (documented as a separate project).
andrew-starrAndrew Starr 11/25/2015 at 09:296 Comments
Today I did some voltage, current and speed tests on the newly-completed counter section:
Supply Voltage (V)Maximum Clock Frequency (MHz)Average Current Consumption at Maximum Frequency (A)
5.011.0
3.31.50.8
2.720.6
It's interesting to note the effect of slew rate when comparing supply rail vs maximum clock speed. So lower voltage is better in this regard. However at 2.7V the LEDs are starting to dim, and since 1 MHz is my target clock speed, 3.3V seems a good compromise.
Now I have to make some 2 to 4 decoder modules to generate the row/column signals from the 6-bit address...
Andrew Starr wrote 11/25/2015 at 20:03 point
I keep forgetting to hit 'reply'....!
Andrew Starr wrote 11/25/2015 at 20:02 point
Most definitely a big chunk of power is used by the LEDs, but they're an important part of the project, so that's fine. I could probably boost the brightness on 2.7V by reducing the collector resistors that feed them, but I don't need the extra speed and 2.7V is an awkward voltage - a high current 3.3V supply will be easy to source.
Yann Guidon / YGDES wrote 11/25/2015 at 20:11 point
2.7V is only 3.3V minus a PN diode drop ;-)
Andrew Starr wrote 11/25/2015 at 20:26 point
And how much current will be going through that diode? Hint: a lot :)
Yann Guidon / YGDES wrote 11/25/2015 at 20:34 point
The "right" way to power something like that is to distribute power and have step-downs all over the place. Some cheap Cray (mid-90s ?) were like that, with a 48V main rail and DC/DC all over the place.
I could send you several high-power step-down modules from TI that their samples program sent me a decade ago ;-) They are quite bulky (newer generations are even more efficient and compact) but can sustain more than 10A each with easily programmable output voltages.
Yann Guidon / YGDES wrote 11/25/2015 at 11:43 point
Awesome :-) Thanks for the numbers !
it's rare to be able to cut power consumption by 3.
Maybe a lof of power is also drawn by the LEDs ? :-D
Could you change the LED system so you can use 2.7V ?
