Trial Core Plane ready
A project log for ED-64: A discrete 8-bit computer
ED-64 will be an 8-bit computer built with discrete components, and will feature a ferrite core memory (documented as a separate project).
andrew-starrAndrew Starr 01/22/2016 at 21:082 Comments
I've populated one of the core planes to experiment with. I've discovered it's quite tough getting that 4th wire threaded, so I will try a 3-wire system i.e. the sense and inhibit circuitry with share the same wire.
The next step is to put together some current drivers and sensing circuitry.
Andrew Starr wrote 01/22/2016 at 21:29 point
3-wire systems tend to be later generation. I've got a pretty good idea how to go about it.
Yann Guidon / YGDES wrote 01/22/2016 at 21:22 point
Most core memories I know of have only 3 wires...
Good luck with the electronics !
