First good part
A project log for Nano-tube
A micromaxx size carbon body rocket.
scott-powersScott Powers 11/25/2015 at 00:470 Comments
The part I tried last night using the sheet protector as a release film worked! The part was by far the easiest to remove, both from the mandrel as well as from the film. Additionally the part is of a size that it can be used with a friction fit motor, using a bit of tape. That makes me think that the motor block will also fit ok into the part. I am attempting to replicate this now with a bit of carbon.
