NeoPixel NeoJoints
Quick angled solder connectors for NeoPixel LED strips
NeoJoints are "joints" for NeoPixel/WS2812 LED strip to make it easier to join pieces together.
Published as a set of Eagle files, with angles of 0, 90, and 180 degrees.
Part of Mill-a-Week, @carlynorama & @todbot's weekly experiments with OtherMill.
Check out the github for updated NeoJoint designs: https://github.com/todbot/NeoJoints
README-hackadayio.txt
Just a placeholder to remind people that all files are on the github.
plain - 47.00 bytes - 02/23/2017 at 20:36
Download
View all 6 project logs
ed.k wrote 02/16/2018 at 22:44 point
I'm trying to just open these files in Eagle and every file gives me an error that they are not Eagle files - what am I doing wrong???
Koen van Vliet wrote 03/04/2017 at 14:04 point
It'd be nice to have these as flex PCBs or even 0.6mm boards. I could have used these in my LED matrix build.
Dave's Dev Lab wrote 03/03/2017 at 21:07 point
great minds thing alike! (or so they say!) i did something similar in the fall of 2015 for a rollup rgb display! http://elinux.org/LED_Matrix_Failure
todbot wrote 03/05/2017 at 18:20 point
Hi Dave,
Those are great! I like the strain-relief additions. Making a matrix with LED strip is exactly why I started on these. (and around the same time too perhaps!)
todbot wrote 03/03/2017 at 18:33 point
Hi Jonathan,
Yes, definitely!  The current designs are optimized for a single-sided bare copper board made on a PCB mill, but I'm making a few small improvements and then will do an OSHpark run soon.
Jonathan Beri wrote 03/03/2017 at 16:57 point
Are you planning on uploading these to OSH Park under Shared Projects?
