Now Using PROGMEM
A project log for Nyan Board
A small ATtiny85 board playing the Nyan Cat tune.
dehipudeʃhipu 11/09/2015 at 22:153 Comments
Thanks to @davedarko's persistence and his #Me building projects from hackaday.io project, there is now version of this song that keeps all the note data in PROGMEM, and thus uses so little memory, that it runs on ATTiny45. The updated code is in the repository linked on the left.
Aleksander Kawęczyński wrote 11/13/2015 at 17:25 point
Great!
You can also avoid all float variables - here modification: (compiles OK, but not tested) http://pastebin.com/0zsRLssJ
deʃhipu wrote 11/14/2015 at 00:14 point
The floats are there only in the surprise version, because it was a quick hack.
Eric Hertz wrote 11/10/2015 at 08:52 point
Ah Hah!
