The Power of Plain C
A project log for Nyan Board
A small ATtiny85 board playing the Nyan Cat tune.
dehipudeʃhipu 11/26/2016 at 13:575 Comments
So I gave up on using that formula, and instead tabulated the frequencies -- that's just 8 bytes, after all. I also changed the encoding of the notes, so that it's easier to read (in octal). The 3 least significant bits are the pointer to the table of frequencies, the next two bits are the octave (with 0 being a pause), and the sixth bit is the duration. That got me down to about 800 bytes.
Hmm, but I'm sure I can do better. At this point, I'm basically not using anything from Arduino itself, except maybe for the delay. So what if I just go with plain C, like the good old days? A quick google found me a ready Makefile for the ATtiny85 (complete with fuse flashing), and a bit of looking around got me the _delay_ms() function. Perfect.
The result? See for yourself:
AVR Memory Usage
Device: attiny85
Program:     492 bytes (6.0% Full)
(.text + .data + .bootloader)
Data:          8 bytes (1.6% Full)
(.data + .bss + .noinit)
If I'm reading this right, that is exactly 500 bytes total. Woo!
The code (with the makefile) is available in the repository here (no rickrolling this time, I promise): https://bitbucket.org/thesheep/nyan/src/495dfa41484dade01bdf7ff79b41f9337f430e5b/main/?at=default
deʃhipu wrote 11/26/2016 at 18:40 point
And another 16 bytes by moving the FREQ table into PROGMEM. It seems that the code that copies it into RAM at the beginning is quite large?
Eric Hertz wrote 11/27/2016 at 02:42 point
haha, 16 bytes is *huge* when you've only got 1kB :)
Eric Hertz wrote 11/26/2016 at 18:30 point
Yowsah!
danjovic wrote 11/26/2016 at 15:15 point
And the most important, using plain C and your own routines keeps the power under your control!
deʃhipu wrote 11/26/2016 at 14:57 point
Shaved off another 6 bytes by using bitfields instead of explicit masking and shifting.
