Measuring I-V curve
A project log for IW blower 2 - pipe
Ion wind blower, second model
deepsoicDeepSOIC 09/29/2015 at 22:110 Comments
Ammeter is measuring a voltage across a diode, that was later converted to a current by calibration measurement separately. Diode (actually, two inverse-paralleled diodes) was used instead of a common resistor way of doing it, because resistor will fail to protect the multimeter in case of a spark across the blower. Diodes are very hard to blow open, they typically die blown shorted. These 1A ones survived sparking no problem whatsoever.
