The recordings
A project log for Ultimate practice room
Convert the X stand included with most keyboards into a table stand with isolation from the floor.
lion-mclionheadlion mclionhead 07/05/2018 at 23:110 Comments
The stand was 1/2" too low, but as suspected, it was real hard to adjust.  Ended up just living with it being too low.  There's either drilling new holes or putting wood spacers on top of the springs, which of course, would change the spring behavior.  Pedaling is real hard, when standing.  Even damper pedaling alone is not as precise.  You have to practice more with pedal.
