Ballast: Update 2
A project log for BorgCube ROV
Underwater robots!
tim-wilkinsonTim Wilkinson 03/23/2016 at 18:230 Comments
Had chance to stick the ROV in the tank and work out the final ballast. For neutral buoyancy the total extra weight was 3 lb & 3 oz (1.42kg in proper money). Here's the final beastie sitting just under the surface, happy as you like.
