Breadboard setup
A project log for Laserworks
A little project that involves cheap laser diodes, e.g. to be used as a little annoying laser show or electronic fireworks, or just for fun.
leonardLeonard 11/06/2015 at 19:140 Comments
While I'm still waiting on the laser diodes to arrive, I've made a simple setup with LED's, and made a little program that seems good enough to do the job. Again, nothing fancy, and yes this is all quite simple. So while the code is done and seems to work good enough, I can continue about my business... and you can too!
..pondering what I should use as smoke.. or mirrors perhaps...god this will blind people.. let's point them upwards ..
Oh and the fibers are for interesting displayal of more but tiny lasor beamz.
Not sure if that will work, we'll see.
