Display Units
A project log for LED Matrix Controller
Replacing an old Lightlink/Inova FPGA Scrolling LED board controller with PIC24F + ESP8266
yadid-ramotYadid Ramot 11/08/2015 at 20:380 Comments
Each display has an array of 16x3 and 20x2 boards, each board contains an array of 10 x (4x8) RGY LED blocks
Boards are serially linked to each other in each row
Each row is connected to the board using a 10 bit ribbon
The ribbons are connected from the main board to a OCT buffer (HCT244) and a shift register
After some poking around, i found the following lines -
RCK (Pin 10)Green Bit
Row ID (3)SRCK
Row ID (1)Row ID (2)
SRCK5v+
Red BitGND (Pin 1)
RCK - Shift Register RCK
Green Bit - Shift HIGH to light up Green pixel
Row ID (1-3) - a 3 bit number for the following rows - (ID 1,2,3)
Row 1 - 000Row 2 - 001
Row 3 - 010 Row 4 - 011
Row 5 - 100Row 6 - 101
Row 7 - 110Row 8 - 111
SRCK - Shift Register SRCK
5v+ - positivie
Red Bit - Shift HIGH to light up Red pixel
