Electronics
A project log for Computer Numerical Considerations
Not the full-fledged CNC project had.io deserves but the brain-dump @esot.eric asked for
stefan-lochbrunnerStefan Lochbrunner 11/11/2015 at 15:330 Comments
The stepper motors seen in the main project image are salvaged from old printers. Maybe I'll write about them in more detail some other time.
To control the motors I'm using StepSticks which are really cheap on eBay and easy to use and are in turn controlled by an Uno.
As you can probalby guess from the image the Uno is running GRBL so nothing fancy here.
