Project completed.
A project log for Baofeng UV3 USB charging station conversion
Add USB charging to UV3 radio
garyGary 11/11/2015 at 20:370 Comments
The project didnt take more than 30 minutes of time once I had the charger board. there is a lot of room in the charger case so no critical tolerances to worry about. Only a few connections to solder so this should be an easy project for even those inexperienced in soldering.
