Arduino Pro Micro HID Code for Toggle Switches
A project log for Real Scania Truck Home Simulator
The Scrapyard and Arduino make a great combination!
jeroen-van-der-veldenJeroen van der Velden 04/27/2018 at 10:040 Comments
Use this code to connect a Toggle Flip Switch to an Arduin Pro Micro or Leonardo.
The pin to connect is Digital PIN 8 and GND
ON will output "a"
OFF will output "b"
Change if you like!
#include <Keyboard.h>
const byte switchPin = 8;
byte oldSwitchState = HIGH;  // assume switch open because of pull-up resistor
const unsigned long debounceTime = 10;  // milliseconds
void setup ()
  Serial.begin (9600);
  pinMode (8, INPUT_PULLUP);
  }  // end of setup
void loop ()
  Keyboard.begin();
  // see if switch is open or closed
  byte switchState = digitalRead (switchPin);
  // has it changed since last time?
  if (switchState != oldSwitchState)
    oldSwitchState =  switchState;  // remember for next time
    delay (debounceTime);   // debounce
    if (switchState == LOW)
       Serial.println ("Switch closed.");
       Keyboard.press('a');
       delay(100);
       Keyboard.releaseAll();
       }  // end if switchState is LOW
    else
       Serial.println ("Switch opened.");
       Keyboard.press('b');
       delay(100);
       }  // end if switchState is HIGH
    }  // end of state change
  // other code here ...
  }  // end of loop
