lwiplib.c Line 192
Edit 3-10-2016:
I think I fixed the problem. From the instructions on the TI Page (http://processors.wiki.ti.com/index.php/LAUNCHXL2_RM57L:_lwIP_Demo)
Where it says to change the function on balls T4 and U7. HALCoGen show this.
The problem is that there is not MII_RX_AVCLK4 or MII_TX_AVCLK4 on these balls, and selecting MII_RXCLK and MII_TX_CLK show a conflict.
So, switching MII_RXCLK from T4 to K19, and MII_TX_CLK from U7 to D19, and going back to the pin muxing tab, and setting the pins there removed the conflict.
I got the following output form ccsI have to wait until the mac address is added to the network to know if this actually fixed anything.I couldn't make any headway after the MAC address was added to the network. The board would hang while trying to resolve the ip address. I rolled back to last nights code, and it worked the first time.
However after restarting the board I got the same results as last night. This works intermittently at best.
I may try this with a static IP, and see if I get better results, otherwise I'm going to go with the TM4C1294XL
